Hi. I'm getting ready to WC for my first time. Before I say anything more, I already spent over a month in research. You may have seen I've posted some questions in some threads already, but now I'm ready to make my decisions. My paycheck is coming soon and I'd like to be ready to order as soon as it does.
I'm willing to spend up to $400 if necessary, but I don't think it will be. To start with I will only be cooling my CPU. (I might WC my 4870's when I get them and perhaps the NB/SB in the future, but not now.) Most important to me is performance, but it would be nice if it was quiet.
My rig is in my sig with one change. I will be using the Asus Rampage Formula which I just got. Oh yea, and I won't be using the OCZ Vendetta 2.
I'm pretty sure about most of the parts, but I'd like you to please look it over and tell me what you think. I also do have some things I'm unsure about an will ask.
CPU WB: Swiftech Apogee GTZ Extreme - $61.95
I understand this is probably the best performance CPU WB.
Rad: Swiftech MCR320-QP - $51.95
I would like to install the entire loop in my HAF932 without any mods, so I need the spacing of this rad. If there's a better rad with this spacing (maybe the Black Ice GTX 360?) please let me know.
Pump: Swiftech MCP 355 - $64.95
with: XSPC Laing DDC Top - $16.95
Res: Swiftech MCRES-Micro Rev. 2 - $25.95
I would actually prefer a res which I can see the water level from outside the case. Is there a res (perhaps a bay?) which will allow me to do that, but won't cause any performance loss? Or is there perhaps some kind of LCD screen that I can put in a 5.25" bay which will tell me levels? If not, oh well.
Fillport: Danger Den Fillport - Delrin - $11.95
The HAF932 has a hole for a fillport on top under the rubber mat. I would like to put the fillport there so I don't need to open the case to topoff the res. I would also like to be able to put the rubber mat over it, so how much of a "bump" does it cause over the case level? Does it make a difference what fillport I use? I chose this one because it's black and seems pretty low. Also, do I want the "Perfect Seal" 1/2" barb or the "High Flow" 1/2" barb? Does it make a difference?
Barbs: 8 x Danger Den Silver Compression Fitting - 1/2" to 5/8" - $6.95 each x 8 = $55.60
I prefer the look of the compression fittings over regular barbs with clamps. If regular clamps are better, please let me know and I will change them. Is this the right size? Do I have the right number of them? Also, will I be able to put one of these in the fillport? If so I'll need to add one more.
Tubing/Additive: For tubing I'm really not sure. I want a very red UV look but I'd rather do it with clear tubing (Tygon R-3603 7/16" ID 5/8" OD Chemical Tubing) and red UV dye, but I understand this may give me problems. Is there a good red UV dye (really looks red) which won't cause me any problems? If not I would go with red UV tubing (Primoflex Pro LRT UV Red Tubing - 1/2" ID 3/4" OD in which case I'd need to change the compression fittings to 3/4" OD) and clear distilled water. How would I be better off?
Additive: Petra'sTech PT_Nuke Concentrated Biocide (10mL) - $2.50
Is there something equivalent I can get from JabTech so I can get everything together?
Fans: I want to use red LED fans, but not if it will lower performance or increase noise (by much). Are there any good ones for this rad? Also, I think I'm going to start with 3 fans unless you think I should just skip to 6.
Coolant: I should just use regular distilled water from the store? Anything I should know to watch out for?
I think that's it! If I missed anything please let me know. Also any comments/suggestion/recommendations and especially answers to my questions are more than welcome.
Thanks in advance!
(I'm not even going to bother adding up the total yet because there's still too much undecided. I'm currently at about $325 though.)
Thanks in advance!
