- Sep 15, 2007
- Small town Emlenton, PA
AIDA 64 Just not what we use for load temps.
Hehe, I didn't do my loop for two years. Don't feel bad. I got lucky. Just do it.
Thanks for the vote of confidence I'll disassemble it all soon and give my setup it's first cleaning. Will do a remount of the CPU as well with possibly some new TIM based on some of the newer tests I've seen.
Any thoughts on the fan setup? I should have explained what my dilemma is a bit more clearly. Currently, my top rad is an exhaust, and my bottom rad is an intake. All other fans in the case (front, rear, and side panel) are intakes.
Would making my bottom rad an exhaust (matching my top rad) help at all with temps? I see lots of people saying all rads should be exhausts, others saying they should be intakes with the rest of the case fans as exhaust... I haven't found anything definitive, but I might have missed it.
Thoughts?
As for adding 2 fans for push pull, the difference will be very small. Think around the range of 1c, MAYBE 2c.
It would probably be a good idea to drain and refill your loop, but you likely didn't do any damage over 3 years unless you had any sort of growth/corrosion. If you feel up to it, it may be a good idea to break down the loop to inspect/clean your waterblocks (especially since you stated your temps have risen over the last 3 years), but if you don't bother your system will still run perfectly fine. I feel your pain filling and draining that monsoon res, i recently pulled mine from my system because it was so hard to drain and fill.
All depends. In most cases, its front + bottom intakes and top + rear as exhaust. In my case, I have a massive case with all filtered points except the rear. I have all intakes and rear as exhaust. No complaints over here. In your case, you should do front + bottom as intake and have top + rear as exhaust. Just make sure the exhaust points don't have filters in them otherwise you're adding way too much resistance for the rad fans and you'll just have fairly warm air re-enter in the circulation.
Very interesting, maybe i'll have to experiment with that, my rad is fairly low fpi, but i usually push for sub 1k RPM.Actually, the studies and tests I've read, its more than 2c. In some cases 5c, if not more. Most of our radiators aren't being fully utilized believe it or not. The sweet spots I've seen is around 2200 for low FPI rads. Meaning a 120.3/320mm rad @ 2200 RPM, I believe it was Martin's tests, has show it cooling 300w of heat dissipation. This is why I recommend a little extra rad, all depending if the end user wants the best delta temps possible and if the case permits.
Monsoon MMRS. Very customizable, and fairly affordable compared to a lot of other options on the market.Sporktar - what is the reservoir that I saw in your build you replaced the Monsoon with?? I don't recognize it (looks similar to the XSPC one).
I had a test bench. Was great. You actually need less fans.
That still seems a bit high for CPU load temps with the amount of rad you have in there with everything at stock. I also noticed the bottom GT fans are set exhaust. I would reverse that and have the bottom as intake and the top as exhaust.
