- Oct 14, 2007
Good morning OCF! I'm here to ask some fan & fitting advice. I'm not "new" to water cooling, but this is the first time I'll be trying to fit it all in my case. Here's the present (and dated) setup.
The new loop is going to consist of (in this order):
So, I need fittings and fans.
Fans: Ideally, I'd go with the same 120x38 Ultra High Speed Panaflos that I already have one of. However, space is tight and I may need to go with 120x25 fans. If that's the case, I was looking at these three blade deltas. I'd lose ~10CFM but gain 13mm; not much but every bit counts.
I welcome any input on those or, if you like other options, any other good fans for water cooling. I know some of you may say Yate Loon. Since funds are limited, I'm trying to stick with one shipping tab, plus the only shop I know that carries them (Petras) is out of stock on the high CFM models.
Fittings: Anybody have a preference for these? I'm not really experienced enough to know what's good and what's not. I was looking at either D-Tek or Bitspower. If it really makes no difference, the D-Tek's will save a few bucks and every penny counts. Comments?
Thanks for any input!
- Swiftech MCP-355 (aka Laing DDC)...
- ...with an XSPC Acrylic res top
- HW Labs Black Ice Pro II
- D-Tek Fuzion v.2 on the CPU
- Koolance VID-282 on the GPU
- ...back to the pump; all run with 7/16"ID tubing.
