- Dec 5, 2001
- Canuckistan
I picked up a monitor the other day. It was in the local Bargain Finder as a freebie. We took it home and plugged it into the wall. The LED on the front turned green (it got power) then turned orange (standby i'm guessing). Then we took a venture to the computer, hooked it up, and still same thing. It doesn't get any kind of video signal but it does get power. How do i find out what's blown in it. Is it the tube, lasers, maybe the big capicitor in the back?
And another thing. Do i need to discharge the capacitor as long as i'm not stickin my fingers under the rubber, or should it be discharged anyway.
If i have to, how do i go about rigging something together to discharge it. Will using the ground on a wall socket plug work?
