Flash Memory Partition
crimedog
South of Boston
I managed to delete everything off my 256mb SD card, and now it's reading as RAW format and windows can't format it. I think I just need to find the right program to format it, no? Could anyone please suggest the name of the software needed?
Thanks!
Using SD card reader on a PC:
Open File Explorer, select SD card reader device. Or, in XP or Windows 2000, select My Computer icon, right-click the icon and select the Card Reader Device. Now right-click the mouse button and select “Format” from the pop-up menu. The formatting will commence.
Using PC with SD slot or PCMCIA/SD adapter:
Select the ‘Start’ menu button on your desktop. Select the item ‘Run’. In the pop-up box type in the command ‘FORMAT’. (For help on this command, use ‘FORMAT /?’) . To start the formatting of the SD card, please enter following observing the syntax accurately: %Drive% /FS:FAT /V:HP49GSD /A:8192 where %Drive% means letter of drive SD card – e.g. G: The SD Card will be formatted.
do you have a digital camera ?? if so try to use it in that agin and see if it will reformat it .. your windows should do it fine .. you may have issues on the card or your reader ..
i was just posting the two different methods for windows .. i seen what you typed..
i think you have an issue with the card then if windows cant do it ..
