- Jun 21, 2002
Update: Here are some recent upgrades to this loop.
Some of you might recall my previous thread for advice and planning for this loop. It's finally coming together! Thank you to everyone in the community for your advice and support, special thanks to GTXJackBauer for his extensive help and advice with this project! Here is the thread for reference.
Components are in sig. Watercooling: EK-Supremacy EVO AMD - Full Nickel, EK-FC Radeon Vega RGB - Nickel, EK-Vardar EVO 120ER BB (500-2200rpm) - White x 6, Black Ice Nemesis 360GTX® Dual-Core Xtreme Profile Radiator - White, EK-D5 Vario Motor, Radikult 360mm res. holes reversed for rear pump mounting, PrimoFlex Advanced LRT Tubing - 3/8in. ID X 1/2in. OD - Elegant White, Bitspower fittings matte black.
First pic is a question, is this bend too tight? It seems to be on the verge of kinking...
Overall shot, what do you think? I considered flipping the CPU block and going res>cpu>gpu>rad, but I didn't like the long tube from GPU back to rad. Probably be less restrictive but I think the D5 can handle this. Going to re-do the run from CPU>Rad so the 90 deg fitting can aim straight up. (this is just a mock up, fittings not tightened and compressions off, no plugs, just FYI in case someone was worried for me!)
Adding additional pics from post below:
Nude Vega 64
No glass
Glass
Nude Vega 64
No glass
Glass
