- Aug 27, 2003
- Mississauga, Ontario
Hello, just a quick inquiry. My newish monitor, in the sig, runs perfectly at 144Hz, and that's great, since that is what I want. But playing Skyrim there are all kinds of problems with anything over 60fps/60Hz, and once you install mods you can't use the fps limiter that comes with AMD, Vortex, the mod manager, handles the game and over-rides any limiter for some weird reason.
So, the only solution I found is to change the Hz of my monitor in windows to 60Hz while playing Skyrim. Now, I only play Skyrim at the moment so I don't need 144Hz, but in 60Hz, while the game is perfect, it flickers sometimes. Definitely on the load screen, not within the game, but also in Windows itself, and movies are completely unwatchable, when I put MPC or Potplayer in full screen, or even a window, it flickers like crazy.
Any solution to this?
I can try to limit fps with Riva, maybe it will allow it, but somehow I doubt it as the limiter on AMD also doesn't work.
