- Sep 21, 2001
- WILDCAT COUNTRY
Never gave much thought to these pumps until today. A few years ago I built a portable water heater for camp use so we could have showers while hunting. When building the stainless tank heater I needed to locate a 12 volt pump. After doing some searching a came across a pump called FloJet. The small pump has a pressure switch set to shut off at 30 PSI. The switch can be removed, but after looking at their website you can purchased the pumps without the pressure switch in 12 volt or 120 volt. I can't recall if the pump makes any sound. I am going to pull the heater out and fire it up. I do recall it having good pressure as I had to lift the water about 6'. I have enclosed a link to the site. To give you an idea as to their size, their about the size of an Eheim 1250 pump. Some models are rated at 60 psi.
CLICK
CLICK
