I'm thinking of trying a different setup in my next case which I will be building next week. I propose to have 2 120mm fans sucking out the top, and 2 120mm in the floor of the case sucking in. The idea of course is to have as straight an air flow path as possible. Has anyone else tried this? Does it help temp control? But most importantly, how much should I raise the case from the floor so the bottom fans will have enough air to suck?
I'd be real grateful for any suggestions as this next machine will need all the airflow it can get. (Dual athlon, Raid 4 server)
