- Mar 12, 2002
- Raleigh NC
Ok, so I have all my systems parts on the way and I am wondering what order I should route my water through the system. I have a 500 GPH pump with res, a heatercore. and a Maze3. Now people have said that a submerged pump will heat the water (though I havent seen much proof of this). So my question is why dont I just run this flow layout:
pump -> rad -> WB -> pump
This way any heat from the pump will be dissapated by the rad then go to the waterblock, then hopefully a small amount of WB heat will dissapate in the res and then also the rad again. Is there any real problem with this setup? Anything I am overlooking? Thanks all.
Josh
Josh
