- Nov 20, 2006
- Benicia, CA 94510
(Resolved) Folder/subfolder problems with shortcut
My System Specs:
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Type X86-based PC
Processor x86 Family 15 Model 4 Stepping 1 GenuineIntel ~3211 Mhz
SMBIOS Version 2.3
Total Physical Memory 1,024.00 MB
Available Physical Memory 566.23 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 2.41 GB
Hard Drive Space 250GB
Recently I have tried to run an old game called "Kings Quest: Mask of Eternity" I set the compatibility for this .exe file that launches this game using the shortcut menu and going to properties on the .exe file to run on Windows 98 and setting the mode for 256 colors, using 640x480 resolution, disabled visual themes, and turned off the advanced text services. After doing all this and clicking apply. I ran the program to play the game, soon after I closed the program I noticed my desktop icons were all set to a blank white icon as well as my entire system icons. I managed to set these icons back to default using folder options, but am unable to change some icons in the "My Documents" folder such as the "Videos" and "Pictures" icons. This however isn't the problem, the problem is that when i try to open the "My Documents" folder it will open it in explore view by default for some reason, and when I try to open a sub folder within the "My Documents" folder such as a folder I have named "Heald College" it will open up the "search results" (the search program that comes with the OS) instead of opening the folder and will display the folder in the "Look in" field. I need to set the double click options on these folders back to default; I've never seen this type of problem happen before which all started with the backward compatability with a 98 program. If anyone could help me out that would be great. I took a few screenshots of the problem if anyone wants to take a look at it, thanks in advanced if anyone can help me solve this problem!
*Edited
Screenshots:
Screenshot 1
Screenshot 2
My System Specs:
SMBIOS Version 2.3
*Edited
Screenshots:
Screenshot 1
Screenshot 2
