FAH Client v7.6.21 has been released. Announcement at Folding Forum.
https://foldingforum.org/viewtopic.php?f=24&t=36307
New Client Released - V7.6.21
Postby PantherX » Fri Oct 23, 2020 3:45 pm
Please note that the latest version of the client has been released: V7.6.21
You can download it from here:
https://foldingathome.org/alternative-downloads/
Please note that the folding performance will not change as that is dependent on FahCore which remains the same across V7.4.X, V7.5.X and V7.6.X
All my hosts have been updated to v7.6.21 and are running fine. 22x linux hosts (2xU1604, 20xU1804) and 2x windows hosts (1xW10, 1xW7). Did have to make manual adjustment to correct the GPU slot/order on two linux hosts.
All the linux hosts have 2x gpu slots and a few have existing cpu slots. No new slots were auto-created. A few of the gpu slots had wu in progress and resumed OK from checkpoint. FAHControl runs OK, but is only configured for the local client. Only issue encountered was that two of the hosts had GPU slot ID/order issue with slot closest to CPU socket being ID as slot 02 and the more distant as slot 01. The GPU model in the slot was reversed on one of the hosts too. Both of these boards (X58pro and P8Z77WS) have had slot ID issues in past and possible that the index had manual config.
The W7/W10 hosts are notebooks and do not normally fold, but have FAHControl configured to monitor/control/config the linux host clients. FAHContol has been running without issue on the W10 host and have folded a few wu on the discrete nvidia gpu 960m. The W7 host is dedicated to HFM, which has been running without issue and also has a copy of FAHControl, which appears to run OK too.
