Foobar Question
Maxvla
Senior Member
OKC
i have a few mp3s that have errors in them and every time foobar plays these songs it comes up with an error window. any idea how to get rid of this window? i know the songs have errors. i don't need to be reminded every single time it comes across one.
james.miller
Dunstable, uk
yes:)
1) Click on Components >> show console
2) on the console window, click on options and un-check popup on warnings.
On a side note, what are your impressions of foobar2000 so far max?
Maxvla
Maxvla
Senior Member
OKC
excellent thanks. those warnings were getting very annoying.
as far as impressions i really haven't been able to spend alot of time really 'listening' to it. too busy shopping and stuff. :eek:
sounds pretty good. i like the waveout instead of using directsound. sounds a bit cleaner. wish i had a decent card in my main rig but i don't think i could fit a sound card in this shuttle XPC without breaking something. next rig is going to have an audiophile 2496 in it so i can use my headphone amp.
james.miller
Dunstable, uk
I'm sure it wont fail to impress:)
did you try the kernel mode? for me at least it's definatly the best of the three. There's also some quality to be had from the resampler plugin, but i think that only really applies to cards with a digital out.
Turd Furguson
Ashland, KY
OT here but I will never return to Winamp after I began using Foobar.
THe kernel option does affect sound quality. I found it is better for me enabled.
Maxvla
Maxvla
Senior Member
OKC
ok very nice. better quality and only 1.9mb ram with 0% cpu. improvement on all fronts.
i'll mess around with this.
i had 0.7.6 but it was the unicode version not the special version.
