- Mar 19, 2001
- Bakersfield,CA
Im getting 70c idle with the fop 38 and 37c system temp 1.2ghz
currently running at 600mhz do to the heat
someone that has the same setup as me is getting 42c idle with coolermaster dp5-6h51 and he lives in the same climate as me=/
now Im thinking that there is something wrong with my heatsink=/
it is running at the right speed the only thing that I think could be wrong is the thermal past that I got at some computer store but will the thermal past realy make that difference I put it on right=/
I dont believe there is realy a bad way of putting a fop38 on the mobo
HELP!!!!!!
HELP!!!!!!
