FOP-38
There are two clips mounting the fan to the HS. Use a small plier to pull the clips down from under the fan/HS, sits in small grooves. Notice wich way they are mounted. Take of the fan and turn it, then put the clips back using the same plier. The clips fastens the fan via screwholes. Take a close look and you will sonn see how it works.
I've become pretty undecided in love - do I love AMD or Intel or my mom ? Time to worry is when I start to love the other men in the laboratory I work in
