you should have bought a 40-50 cfm 80mm fan and mounted that on it, I have a 47cfm ys-tech 80mm fan and though some of the air flow is lost due to the overhang it performs as well as a delta and at much lower volume, your temps do sound high though, are you using the pink pad or some thermal compound
