For a lv 29 hunter on wow where is the best spot to lv?
iwillpeeon
michagen
For a lv 29 hunter on wow where is the best spot to lv at? Also i play about 10 hours a week ho long will it take me to get to lv 60?
Shimmering flats and stay there until around 34-36? Then go to scarlet monastary over and over and over, until you are 40.There is other places but that's the fastest way.
If shimmering flats is to high for you (might be 30+) you could go kill harpies.
As for your question of leveling.. you post more than you play :p So not sure, But in all seriousness it all depends on you. For some 10 hours a day is 1-12 for others it's 1-25. Just depends if you know where to go to level.
Instead of making a new thread you could just post in your same threads though. But I highly recommend you go to some WoW sites and try your luck there, they do have guides that cover exactly what your asking. wowguru.com curse-gaming.com allakhazam.com thottbot.com
lvl 60 took me a few months to get tol. I played as often as could. I played so much in fact my wife made me quit for awhile. lol.
Then my computer died and i've been detoxing off of WoW for about 6 months now. As soon as my new system is built though... i'm going back to WoW / BF2 / F.E.A.R.
im allience and how do i get there from arburnine
im allience and how do i get there from arburnine :drool: i gotta get there and level. PLEASE TELL ME HOW TO GET THERE AND IF ITS A HORDE CONTROLLED PLACE TELL ME HOW TO GET THERE. P.s. I am at school and so i cant play wow. P.s.s. I can only play an hour a day exept on weekends so its not even worth playing wow because ill have to get off as soon as i get on. P.s.s.s. I cant acess the wow sites from schoolbecause of the dns gardean. P.s.s.s.s I cant use proxy sites because it doesnt work with the wow forum site.
I'd hit the Eastern Kingdoms. Yes, run Gnomeregan. You can try Wetlands if there's still some quests, perhaps hillsbrad or alterac mountains.
I'd DEFINATELY start running SM promptly at 34, getting all the mail you can.
7
