- Mar 8, 2002
- Near -Seattle-
I was thinking about RAID HD's a couple hrs. ago and an idea occured to me that cannot be right, or it would already have been done.
I hope that someone can tell me why it will not work.
This is my idea:
Instead of buying TWO 40GB HD's to configure in a RAID configuration; why can't the same job be accomplished with ONE 80GB HD??
As I understand it 40GB can be put on a single platter, an 80GB drive would then have two platters in it. Each has its own read/write head, and if the wiring to them is designed properly, couldn't each head be considered as a seperate
40GB HD?????? The only thing I can think of that is NOT independent is their drive, they spin in unison, but that shouldn't hurt anything should it?
If this could be done it seems that one 80GB HD should cost less than two 40GB ones, the case heat buildup should be less, and a drive bay would be freed up, etc etc. All multiple platter HD's could be made with a user option, (-sw.-jumper-bios-) that would allow RAID or NORMAL configuration.
Wouldn't THAT be nice, you could run an A-B test on the spot with no additional purchases and determine how effective RAID was in your set-up!!
Appoligize for length of this post, will keep them shorter in the future.
Please tell me where I headed out into La-La land.
Thnx
eff86
This is my idea:
Thnx
eff86
