forcing 1152x864 on a TNT2
attack
Ok my main rig runs at 1152x864 and my secondary rig which is on a KVM switch (so it uses the same monitor) has a TNT2 that will run at either 1024 or 1280...there is no option for 1152, is there a way to make it do 1152 because at both 1024 and 1280 they look horrible on the monitor and I don't want to spend 5 monutes resizing the monitors everytime I switch....any help on this?
I'm guessing this for the desktop. I would use the "default monitor profile" which allows you to change to whatever resolution you want.
-PC
I tried that and i'm still havin the same problems...any othe4r suggestions?
