- Oct 15, 2001
- Tennessee
Very good work, dustybyrd.
Susquehannock said:One thing though ... if the two units are that similar
why not get the Fortron for $30 less?
Fortron = [/B]
Lithan said:Fortron has fully adjustable, if slightly confusing voltage control.
Which model has it? Can it be accessed without breaking the warranty and can it be tweaked on-the-fly like the Antec's? [/B]
dustybyrd said:...you are referring to the antec true control 550?
Susquehannock said:IMhO ... if there is need to adjust the rails something's wrong.
blkgti said:
I'm not sure if I understand, as I've yet to come across a PSU with perfectly adjusted rails right out of the box. If you meant adjusting the rails all the time, then I'd agree with you, but adjusting the 12v rail (for example) to deliver 12v and not 11.85v isn't unreasonable.
Susquehannock said:
BTW ..... just ordered another 300w Fortron for
another system I'm building.
For $32 delivered you can't beat the quality of the
300w P300XFPN.
Susquehannock said:
Fortron update: ..............
The 120mm fan model listed above isn't what I thought
it was going to be.
For one, it's more noisy than the 300w 80mm back fan model.
(fsp300-60atv)
But according to my DMM both PSU perform exactly the same
in my system. Not only that, the fsp300-60atv gives me
lower system temps as well. At least in my case.
Lower temps & and noise with the same stable rails?
Guess which I'll be buying next time.
cmcquistion said:
If you don't mind modding, that PSU is easy to mod for low noise. I've modded five of them like this... disconnect the fan from the temp control circuit and hook it up, directly to the 5V line. Let it run 5V all the time and your case airflow will still be good, but the noise will stay very low.
