- Feb 5, 2005
- Christchurch, New Zealand
- Thread Starter
- #61
Attn Unlimited Xtreme Class.
Gomeler, Matt and Todd.
This is an (all most) anything goes class!!
In this class you can use (all most) whatever hardware you like.
You could post your stockscores with a E6600 and 7900GT if you wanted, and then bench with a QX9650 and two 4870X2's.
This also means you can change cpu's per test. ie: E8600 for SPI and a QX9650 for wPrime etc etc
But to be it this class, Maxi and myself have to be sure you have the time, skills, hardware and cooling needed.
If this does not sound like you, please let us know asap.
Many thanks
Dean
My main question is...it says unlimited downgrades...would going from 2x 3870X2's to a single 4870 X2 be concidered a downgrade?
Been thinking about doing that on XP runs then using the quad setup for vista runs...just want to make sure on the rules before hand...
same question as glock diff hardware.
which CPU of the 2 in my sig is considered better and therefore swapping to the other would be a downgrade?
I'll come back to both of you soon on those
