Once you purchase a key, and you use register it as many times as you want?
Also, the basic version of 06 is free, can that be used?
Once you buy the key and register Vantage; you won't have to register it again unless you format your HDD and have to reinstall from scratch.
There is zero need to purchase any license for 06 for FWs... The free version allows you to save your results to a file on your HDD, or a USB jumpdrive if you prefer. You can then go to a PC that has web access and also has 06 installed, fire up the program, right click on the main window and select "Submit Saved Score" from the menu... It will prompt you to select the file you had saved previously and once you hit OK, It will send it in to the ORB where you'll be able to get your validation URL.
_____________________________________________________
I'm such a dufus!!!!!
I wanted to make sure that the $6.95 license for Vantage would allow saving your results file for later submission... So I go to the site and select what I thought was 3DMark Vantage from the drop down list, I get to the page and without even looking I click on "Get It" for the Basic License and go on my merry way to pay for it via PayPal... The whole process is done in 30 seconds and I get my key, so I fire up Vantage and enter the key to register it; only to get this:
"YOUR KEY IS INVALID"
Double checked the key, copied it from the confirmation page three times, pasted it three times and every time:
So I go back to the confirmation page and start reading more carefully; instead of just scrolling down to the part where the key is written and guess what?
I just bought a license for PCMark Vantage!!!... I swear to God; I should just take myself outside and throw myself a good beating!
I sent an email off to their sales contact to see if they'll exchange that key for one that I can use on 3DMark Vantage.
Will have to wait and see.
