- Mar 7, 2008
- Thread Starter
- #41
It took some figuring out, but as far as I can tell that ebay kit takes a PCIe 1x connection and takes it to 2xPCI. Unless you got a different version of the server than me, there is no 1x to connect it to. The USB connector I don't think is actually USB and is used as a non-standard connection.
- - - Updated - - -
I found two Hyper 212 plenty for cooling the 2650s that came with mine. Wouldn't look to spend more on it than necessary. Doubt you can OC without extreme modding. The VGA chip on there, I think I got 1280x1024 or similar with the Windows Standard VGA driver, but after installing the actual one for the chip I seemed to be limited to 1024x768.
- - - Updated - - -
