- Nov 18, 2011
- Destin, Florida
Alright so I've finally cleared my schedule for some hardcore Skyrim action and Afterburner has my FLS into the low 20s in some places. I understand Skyrim is very CPU dependent and only utilizes 2 cores, and yes agree the amd processor will bottleneck on games, so an OC seems to be in order. Any OC advice you guys could give on good settings to get at least4.2ghz, as well as maximize the rest of my system, would be appreciated.
Of Relevance:
MSI 990FXA-GD80
1100T BE
Arctic Cooling Freezer 7 Pro Rev. 2
Crossfire PowerColor 6850 (ps do not buy P.C.!)
8gb (4x2gb) Gskill Ripjaws 1600 model f3-12800cl9d
Crucial RealSSD C300 SataIII
Thermaltake Black Widow 850w
2x 23'' AOC Monitors
Antec Lanboy Case: modified to mount MB on left side of case. This setup isn't standard but with this particular case and the way fans mount I've found the change helped my idle and load temps drop 2-3* for CPU, even more for GPU.
This jacked up bios has a few options, some I've played with but no luck more than the Auto o/c genie gives me.
Current settings:
CPU Frequency (grayed out): 200 x 16.5
Current DRAM Frequency (grayed out): 1333MHz
CPU FSB Frequency: 200
CPU Ratio: Auto
Adjusted CPU Frequency (grayed out): 3300MHz
AMD Turbo Core Technology: Auto
Adjusted CPU-NB Frequency (grayed out): 2000MHz
DRAM Frequency: Auto
Adjusted DRAM Frequency: Auto
Adjusted DRAM Frequency (grayed out): 1333MHz
DRAM Timing Mode: Auto
HT Link Speed: Auto
Adjusted HT Link Frequency (grayed out): 2000MHz
PCI-E Frequency (MHz): 100
DRAM Voltage: Auto
NB Voltage: Auto
CPU Voltage: Auto
CPU-NB Voltage: Auto
CPU PLL Voltage: Auto
SB Voltage: Auto
HT Link Voltage: Auto
DDR Vref Voltage: Auto
CPU DDR-PHY Voltage: Auto
NB PCI-E Voltage: Auto
DDR VVT Voltage: Auto
Spread Spectrum: Disabled
An awful lot to take in for someone who hasn't had the opportunity to learn more than very basics of OCing. If anyone cares to suggest some tweaks I'll run comparative benches and see what the best bang is.
Of Relevance:
MSI 990FXA-GD80
1100T BE
Current settings:
CPU Ratio: Auto
HT Link Speed: Auto
DRAM Voltage: Auto
NB Voltage: Auto
CPU Voltage: Auto
SB Voltage: Auto
