Hello,
I’m working on my 1st PC build, with very limited technical knowledge.
The case that I’m strongly considering buying is the Fractal R4. The minimalistic look of the case really appealed to me. However, I want to make sure that I don’t overlook a case that may fit my needs. Noise, Cooling, and functionality are important to me. Also, it must have USB 3.0 ports in front. I am not looking for a case with a glass panel or a lot of lights.
1) Is there a case that has a better internal configuration than the Fractal R4?
2) Regarding the Fractal R4, does the side acrylic window panel add to the noise level?
3) OT: Any recommendation on which Noctua fans to purchase, if I do decide on the R4?
Below is my current configuration (all products have been purchased):
HARDWARE
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard: ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821
Video Card: EVGA GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card 02G-P4-2678-KR
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130787
Hard Drive: Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB Cache Internal Desktop Hard Drive Bulk/OEM - WD1002FAEX
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
CPU Cooler: COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
SSD Hard Drive: Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=20-148-442
Memory: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile Desktop Memory Model CML8GX3M2A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
Optical Drive: Lite-On LightScribe 24X SATA DVD+/-RW Dual Layer Drive IHAS424-98 - Retail (Black)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
Monitor: Dell UltraSharp U2412M Black IPS Panel 24" 8ms Pivot, Swivel & Height Adjustable LED Backlight Widescreen LCD Monitor 300 cd/m2 DC 2,000,000:1 (1000:1) http://www.newegg.com/Product/Product.aspx?Item=N82E16824260047
Speaker: DELL UltraSharp and Professional Series 468-7412 10 W 2.0 AX510 Flat Panel Stereo SoundBar http://www.newegg.com/Product/Product.aspx?Item=N82E16836260002&Tpk=Dell AX510
Power Supply: ?
Case: ?
SOFTWARE
Operating System: Windows 7 Home Premium
Productivity Suite: Office 2010 Home & Student Edition
HARDWARE
Power Supply: ?
Case: ?
SOFTWARE
