SOLVED FREE Xigmatek (after MIR)
still you can get a fan for free i even see some 200mm fans which is normaly $20
free is good
In for 1
Going to replace the front fan in my wife's case.
It's making this horrible noise like it's hitting wires but it's not.
Driving me freakin' crazy when she starts her computer.
You can still disable LED if you look at the wires connecting LED to the fan hub. Disconnect those and it's disabled. Usually it's permanent since it's hard to fix and re-enable LEDs.
Personally I haven't had good luck with this brand of fans. One got crazy noisy in under 6 months. But for free.. what the heck?
Edit: One of the 200mm fans says limit 5 per household..
Rebate form has this one line rule about the number: Offer limited to end-users only. Limited one item per offer, per person, household, family or address.
Sounds like only 1 free fan in the end no matter how many you ordered off Newegg.
I suppose I could do that, I just figure it's simply going to be simply _another_ fan in my NAS, and since I already have a 140mm and 5 120mm fans (if you include the PSU fan) in it, it was more of a "whichever is easiest since it's probably useless" decision.
