I thought I was very lucky to receive a custom built machine from my sponsor in order to order to more quickly process some heavy mathematics, but now I'm not so sure. I joined overclockers.com because you folks seem knowledgeable and helpful. With that said, now I'll ask my question.
The computer runs an AMD FX-9590 cpu on an ASUS Sabertooth 990 FX R2.0 motherboard. I need for it to run 100% for hours on end but the screen freezes, or it otherwise faults. sig-fault 11 mostly, or sig-fault 9 sometimes, and it freezes sometime between 3 minutes and 6 hours into the same heavy math test job. It attempting to isolate this problem I have unplugged everything except the 480GB Kingston SSDD, the usb mouse and keyboard, the video card, the Corsair liquid cooler and the (totally indecipherable name) 750 Watt power supply. The machine arrived bare, in the shipping box that the Zalman z3 plus case had been delivered in. It had been treated roughly. I plugged the dvd reader back in, installed Ubuntu 15.10 OS plus my math code and started repairs - first was to stabilize cpu temperature. It now holds steady at about 48C under load. I next replaced the nice, expensive (and broken) video card with a low prices unit. (PNY nvidia geforce gt 710)
I have isolated the cause of the problem to the memory. Runs fine with 8, 16 and 24 GB memory (DDR3 1600 MHz) installed, in any configuration of the 8 GB memory cards, installed in any configuration of the 4 memory slots, but will not run with all four slots filled. The test job progresses about 40% faster with 32 GB memory installed so I want to solve this freezing problem. I think the problem is related to memory voltage drop under load with 32 GB installed but my one attempt to increase memory voltage resulted in a quick failure with a scary BLACK screen shortly after starting the test job. So I joined overclockers.com. I'm not an overclocker, I don't even build computers, this is not an overclocking question except for the FX-9590 being factory overclocked but that seems to make it an overclocking problem to me.
My question then is, what bios adjustments are needed to stabilize the memory io and preferably at full speed, 4.7 GHz?
My most heart-felt thank you to any and all who help me to solve my freeze problem.
Steve
Steve
