Freeze problem (i thought my hardwares are enough)
hiperaktif
Hello,
My computer freezes when i play game.
(games : need for speed shift and counter strike: source, these games are only game i play)
I tried windows vista, it freezed
I tried windows 7 RC, it freezed
I am currently using windows XP Service Pack 3 and it still freezes.
I installed XP for just stopping this issue. I loved windows 7 but i thought this problems are based on vista or 7. I failed.
When i play, my GPU temp is approx. 50C, my CPU temp approx 60C.
I made a report using everest.
here is my hardware list.
Please lead me about problem.
i have fan for cpu, and graphic card (included)
also i have chassis fan (5000 rpm)
voltage values
Code:
    Voltage Values:
      CPU Core                                          1.23 V
      +3.3 V                                            3.30 V
      +5 V                                              4.92 V
      +12 V                                             11.71 V
      +5 V Standby                                      3.92 V
      VBAT Battery                                      2.98 V
      Debug Info F                                      0077 002D 0000 0000 0000
      Debug Info T                                      58 44 27
      Debug Info V                                      4D CE BA B7 B7 00 00 (01)
p.s. : i have latest drivers
Code:
CPU Type                                          QuadCore Intel Core 2 Quad Q6600, 2400 MHz (9 x 267)
Motherboard Name                                  Asus P5VD2-MX  (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 2 DDR2 DIMM, Audio, Video, LAN)
Motherboard Chipset                               VIA P4M890
System Memory                                     3008 MB  (DDR2-800 DDR2 SDRAM)
DIMM1: OCZ XTC Platinum OCZ2P8002G                2 GB DDR2-800 DDR2 SDRAM  (6-6-6-18 @ 400 MHz)  (5-5-5-15 @ 333 MHz)  (4-4-4-12 @ 266 MHz)
DIMM3: OCZ XTC Platinum OCZ2P8002G                2 GB DDR2-800 DDR2 SDRAM  (6-6-6-18 @ 400 MHz)  (5-5-5-15 @ 333 MHz)  (4-4-4-12 @ 266 MHz)
Video Adapter                                     NVIDIA GeForce 9500 GT  (512 MB)
Disk Drive                                        FUJITSU MHZ2160BH G1 USB Device  (160 GB, 5400 RPM, SATA-II)
      Disk Drive                                        ST3160021A  (160 GB, 7200 RPM, Ultra-ATA/100)
      Disk Drive                                        ST380011A  (80 GB, 7200 RPM, Ultra-ATA/100)
      Disk Drive                                        WDC WD1600AAJS-00PSA0  (149 GB, IDE)
    BIOS Properties:
      Vendor                                            Phoenix Technologies, LTD
      Version                                           ASUS P5VD2-MX ACPI BIOS Revision 1017
      Release Date                                      04/30/2007
      Size                                              512 KB
      Boot Devices                                      Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
      Capabilities                                      Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS
      Supported Standards                               DMI, APM, ACPI, ESCD, PnP
      Expansion Capabilities                            ISA, PCI, AGP, USB
    Processor Properties:
      Manufacturer                                      Intel
      Version                                           Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
      External Clock                                    266 MHz
      Maximum Clock                                     3800 MHz
      Current Clock                                     2400 MHz
      Type                                              Central Processor
      Voltage                                           1.2 V
      Status                                            Enabled
      Upgrade                                           ZIF
      Socket Designation                                Socket 775
Graphic Card Detailed Report
Code:
    Video Adapter Properties:
      Device Description                                NVIDIA GeForce 9500 GT
      Adapter String                                    GeForce 9500 GT
      BIOS String                                       Version 62.94.3C.00.00
      Chip Type                                         GeForce 9500 GT
      DAC Type                                          Integrated RAMDAC
      Memory Size                                       512 MB
    Installed Drivers:
      nv4_disp                                          6.14.11.9062 - nVIDIA ForceWare 190.62
    Graphics Processor Properties:
      Video Adapter                                     nVIDIA GeForce 9500 GT
      BIOS Version                                      62.94.3C.00
      GPU Code Name                                     G96GT
      PCI Device                                        10DE-0640 / 0000-0000  (Rev A1)
      Transistors                                       314 million
      Process Technology                                65 nm
      Bus Type                                          PCI Express 1.0 x16 @ x16
      Memory Size                                       512 MB
      GPU Clock (Geometric Domain)                      500 MHz  (original: 550 MHz)
      GPU Clock (Shader Domain)                         1250 MHz  (original: 1400 MHz)
      RAMDAC Clock                                      400 MHz
      Pixel Pipelines                                   8
      TMU Per Pipeline                                  1
      Unified Shaders                                   32  (v4.0)
      DirectX Hardware Support                          DirectX v10
      Pixel Fillrate                                    4000 MPixel/s
      Texel Fillrate                                    8000 MTexel/s
    Memory Bus Properties:
      Bus Type                                          DDR2
      Bus Width                                         128-bit
      Real Clock                                        364 MHz (DDR)  (original: 400 MHz)
      Effective Clock                                   729 MHz
      Bandwidth                                         11.4 GB/s
    Miscellaneous:
      Fan Speed                                         71% (i made this)
    nVIDIA ForceWare Clocks:
      2D/3D                                             GPU: 500 MHz, Shader: 1272 MHz, Memory: 366 MHz
Did you overclock? If not, then set your voltages to auto and see what happens.
thank you for your reply,
The voltages values I gave above cannot be changed in BIOS.
There is only two section in voltages
one - disabled
two - it's own value
I couldt change it.
is there any program to do that?
and i didn't overclock.
