Ok, I have a lil problem with my new PC inside freezer setup.
This is how I worked it up...I have my motherboard/cpu inside the freezer along with a pump and a res full of anti-freeze. The pump sends anti-freeze that's at the temperature inside the freezer directly to the waterblock (no coil or anything). Now im getting pretty stable temps around 0C over a short period of time (30-60 mins) but if I leave the computer working at 100% for long enough (couple of hours) the temp inside the freezer slowly rises raising with it the anti-freeze temperature so the CPU temp goes up. I test this with a LONG test (played Tribes 2 all day) and I was able to really see how this pattern goes.
Now, the real problem is...even if I were to add a coil or something would it really make a difference? Because it's a close system and the heat generated by the CPU would still be the same and would remain inside the freezer, I think im screwed.
Anyone have any ideas?
(PS : Sorry if I dont have any pictures or if this text is barely readable, I haven't had time to take picts yet and I wrote this in 2 mins. ;p)
