Morning everyone. Last night I was modding some thermal probes on my PSU and heatsink and changing my wiring on my box. When I started the system up to check temp reading I noticed that the CPU hit 95c before I pulled the plug. Now if the probe registered 95c I can probably add another 20-30 degrees to that for a true core temp. Since then nothing happens with my system, everything powers up fans, hard drives etc., but I don’t even get a power test. Took everything out except the cpu (memory, graphic card, nic & sound card) shouldn’t I get the test failure beeps when I start up? Is this a pretty good sign the cpu is trash? Does the cpu have to be in in order for the power test to take place or could it be my MB is bad. Appreciate any insight on this one.
Thanks>
Thanks>
