- Oct 9, 2003
- Illinois
OK. My computer isn't done yet (still need memory and a video card) but I have enough to play with the fans. I have everything hooked up, and the very loudest fan on my comp is the front 90mm intake! I can turn that fan down about 1/2 way and just then it matches the rest of my fans that are at full speed. I have the exact same 90mm on top of my CPU and it doesn't make this much noise. I am guessing it's because it's trying to suck air through all of those little holes in the front. I took off my front bezel and it still made the same noise so I know the bezel isn't blocking too much air. My front intake is meant for a 80mm but I modded it and actually added intake holes to help it...
Here is my comp..
http://www.spudfiles.com/computer.htm
And here are some pics of the front of my case....
(pic 16, 17, 18) yes a ghetto rigged fan. (one of the original holes was too close so when I drilled the second hole I ended up with a long hole, so I used a washer )
I can't just cut out the entire square because see how parts of the middle are still solid? That's because the buttons are right in front of it and you don't really want it eating wires.... what should I do?
And can anyone tell me what this is for? Pic 19 is what it looks like on the back of the bezel, and pic 20 is what it looks like from the front. It's along next to the USB and Firewire front I/O ports... it's labled as LED, but I still don't understand what it's for. Thanks
Here is my comp..
