?????FSB@133 @100
kieran_d
Ireland, Belfast
I have a FIC AZ11E motherboard with the KT133 chipset. The thing i am not sure about is will it support the 266mhz FSB alothons. I am currently running a duron 750@803 (107*7.5=803) that is the highest that i could get with out frezze-ups. The reason that i am asking this is that on fics site www.fica.com in the support part under bios upgrades there is a sentence that says added code for vt8363a 133 cpu support. And i have the latest version of the bios for my board.
Thanks
According to the FIC website, it will run up to a 1.3 gig T-bird @ 200fsb.
Sounds like your current system needs some better cooling. you should be able to get more than 803mhz out of that chip. What HSF are you running?
What RAM ?
Id go for the BIOS upgrade casue at work we got a sys with the same board and the same chip running at 950-and thats being conservative-try your cooling method should be able to hit 900 with that combo-but all systems are different-
