FSB and ep-k7a
Devinaino
i wanted to bounce this off you guys its about fsb over 133 i have 2100 ddr micron memory and a duron 750. i am not messing with unlocking it so i go the other route. question when i tried 140 it made my machine generally unbootable and my bios had to be clear as it would give checksum errors any ideas why?
I was getting problems like that, you need to change the jumper that controls the 100/133 fsb. Its default is 100 so you should change it too 133 (its located right above the ddr mem voltage jumpers)
Hope this helps you
good coincidence i just did that but i havent tried higher fsb than 133 i guess it must be the resetting of the agp and pci buses thanks:)
