I've been to 345 on the A8N32-SLI-D, though I think 330-335 max is typical.ninjacore said:you had 330 on your a8n32 or did you get that on an a8n regular? My question is what max FSB everyone has been able to get on their a8n32's?
5billb said:I've been to 345 on the A8N32-SLI-D, though I think 330-335 max is typical.
Nebulous said:5
Is this with a divider or 1:1? Max i can get without it barfing is 285-ish, yet my ram did 310 on several DFI boards.
ninjacore said:285!?!
that sucks. Was that just a fluke on yours or is that common? I need at least 300
Uh? What does a divider have to do with Max FSB?Nebulous said:5
billb said:Uh? What does a divider have to do with Max FSB?
I'm Just saying that the MOBO (A8N32-SLI-D) will do FSB 345 for me. Obviously, with a low multi and low divider. Though I do have some TCCD that will go 332.5mhz...286 x 10.5 with a 233 (7:6) divider, 3-4-4-8, 1T @ 2.75v,
Perhaps I just see the same issue differently. If my MOBO will do 330 FSB, but with a !:! divider I can only get to a 285 FSB, I dont see that as a MOBO problem, I see it as a memory issue. Which leads to the question "Will changing latencies to get higher memory speeds (and hence a higher FSB) benchmark better or worse?"Nebulous said:You just answered your own question with this statement: " I'm Just saying that the MOBO (A8N32-SLI-D) will do FSB 345 for me. Obviously, with a low multi and low divider"
That was what I was asking, ty. Not all boards/ram will do 300+FSB @ 1:1. The A8N32-SLI-D (which I have in my current setup) refuses to do 300, doesn't matter which chip, ram or bios i use. Now on the DFI (Ultra-D & Expert) i was able to do 310+ and that was 1:1. I don't use dividers.
It was hard enough to find multis and dividers that would keep the CPU and memory speed the same at two different FSBs...and you want temps too. I don't think I can help as I have no way to measure NB temps. And at FSBs of 200 and 250, I'm so far underclocked that MOBO and/or CPU temp differences would be extreemely small.QuietIce said:Did you happened to measure temps under those conditions, too? My heat sensors are so bad I'd probably never see a difference.
It seems to me the higher "FSB" would use more power and generate more heat but maybe the reference clock is so small a part of the system it simply doesn't matter ...?
Its not a big deal really, the DFI expert can do 500mhz HT in lower multi.jeep4x4055 said:wait 345FSB from 200?!! how the hell do u do that the highest i could go with my 4400 x2 is 245 @ 2.7ghz is there something im doing wrong.?
