- Jun 22, 2007
- Dark Side of the Moon
Looking good! I don't want to discourage you from trying to push it any further, but as it's been mentioned before 254 bus speed off that board is fantastic! And unfortunately it could be nearing the top end of it, if not already there.
Rat sums it up pretty well in this post, and what you managed to get out of that board is great to what the typical results were for it. The one thing that you can still do, and I'm not sure if you're waiting for the new heatsink to do it, but try pushing it upwards of 1.42v or 1.45v.. or more if you can keep the temps down. With the new heatsink cooler it should be able to handle what extra heat comes out and see what extra speed you can squeeeeeze outta her.
If it stops at a certain HTT bus speed, even after lowering the CPU multiplier, you've got one of two problems.
a) That's as far as the motherboard will stably operate the CPU. There is a point where the HTT speed just can't be pushed any further without losing its signal integrity.
b) Your memory has hit a wall; you'd usually have to lower the memory multiplier to keep it within its operating spec.
To be honest, 253HTT is way faster than a micro-ATX board with a skimpy 3-phase VRM, based on the dumpy GeForce 6150 chipset has any right to go. Lots of these won't ever go higher than 220HTT before something goes stupid. On top of that, the power circuitry on the board will only support a 95W CPU, so overclocking will never be its high point to begin with.
But before giving up on it, check your memory and HT Link multipliers. If you can lower both of these and it still won't clock up, you're simply motherboard-limited, something that I wouldn't see as a surprise one bit.
