FSB on KK266
Jeppe
When i change the fsb in bios to 160 for example. It say when i start my computer that its only DRAM CLK 133 but the CPU is running 1200 (I have a 1gig 266 not unlocked) is there somthing i must change in bios to rise the memory bus or what????????
And I cant run my ram in cas 2 or 4 bank intervaling will it help to inrcreas vio 5% or 10% ?
I have a kk-266 R 0426 bios and a 1000Mhz AVIA 9 (I know not the AXIA but I dont care so much mayby I can do some O/C anyway)
Please help my this is my first AMD setup and so far I like it.
When the computer post it will only say 100 or 133 depending on where you have the jumper set but in the bios if you have it set higher it is running at that speed. I think at the post the 100 or 133 is just a reference of the jumper. hope this helps
Thanks alot that relly help me. I can boot up at 160 fsb with my cheep ram and isa nic but do you think that could hurt my agp card or my SB live card?
thanks andy I was going to mesion that also but forgot in the above posting that a good idea !!!!
