- May 27, 2002
- Purdue University, IN
SOOO COLD. Um whats preventing liquid nitrogen from condensing on the head of this thing? Neoprene will crack, silicone will harden and contract, dielectric greese will most likely freeze.
madcow235 said:SOOO COLD. Um whats preventing liquid nitrogen from condensing on the head of this thing? Neoprene will crack, silicone will harden and contract, dielectric greese will most likely freeze.
Effulgence said:You do realize that at temperatures around LN2 the transistors basicly fall apart? Going colder and colder is not going to keep helping, especially in the life of the hardware, at a certain point.
CreePinG_DeatH said:Wouldn't a good use for that be a cooler for a lan party that has water cooled PC's and all dumps into one resevoir?
Chris_F said:
No, a offic AC compressor would work better. You would need a larger heat capacity, not lower temps. At a lan party with a lot of computers, you would have maybe 10,000Watts of heat. That helium compressor would die under that kind of load.
Chris_F said:
Yes, sometimes a CPU will just stop working at that kind of temp. I don't really think this kind of cooling would be for 24/7 use because the silicon would eventually crack from going from room temp to -200C, then back to room temp.
cstarritt said:i agree, having a cpu at -150C 24/7 would be the most reliable you could get. you would just have to make sure prime95 was ALWAYS running or it might cool down a bit more. the biggest danger would be initialy cooling it down, as if you go too fast you will crack the cpu in half.
i doubt his setup is gonna work well for long term use though. with helium everything has to be PERFECT for it to be leak proof. think aobut helium ballons, the helium atoms are so small they escape THROUGH the rubber. the tiniest imperfection in any of the components means a leak.
