- Feb 11, 2002
- U.P. Michigan
I got $300 to burn. Here's my design for my existing system. Dual rads and pumps with directional flow arrows on the drawing.
A few points:
Six 120mm fans on the rads that I want to control by a rheobus.
Two existing 80mm side blowhole fans not shown in drawing, one is across from gpu other is across from mem/cpu area.
Two existing 80mm fans at top rear of case. I'm not sure what to do with them. If they draw air in for the top radiator then they would be drawing the exhaust from the psu but if that's not really that warm then it may not matter.
My artistry is not that good but I think the main points are illustrated. I'm thinking dual pumps will help because of the long tubing length with the dual radiators and slightly longer loop of clear tubing. I have the space for dual radiators in the case and want to stay as close to ambient as possible when upping my voltage and possibly trying out a pelt later on (and yes I've used one before but with air cooled Alpha Pep66 on a PIII700).
Am I going to gain much by the dual rads and pumps?
A few points:
