I made myself an 80mm to 60mm adapter with two plexiglas squares and a kitchen funnel (idea from tril0byte) and I put on it a sunon 31 CFM rated at 25db to replace my sanyo denki 19cfm 28db on my pal6035...
My temps have increased a little (?) but my noise is reduced as well. But I thought those 31cfm would allow lower temps than my former Sd 19 CFM...
The sunon is set on sucking (as Alpha recommends it) and I was wondering if the higher distance between the fan and the fins is not the cause of that performance decrease (maybe intake is now too far from the fan? ) ? Maybe should I set the sunon blowing but PAL6035 is said to perform better on sucking isn't it? Any advices are welcome.
