- Apr 18, 2001
- Houston, Texas
ok.
I'm sure i'm not the only one who has had this problem before.
i'm not sure if it did it on windows 98 too, but definately for sure on win 2k and xp. so when you go and look up porn and you right click the image to "save as" it lets you choose either jpg, which the image usually is anyways, or bmp. after awhile, say 3 months of heavy porn website use, it will only let you save it as a bmp and the only way to get it in jpg is to either use photoshop or to exit the pic on the website and click on the pics thumbnail and say "save target as" which will allow you to save the pic as the original jpg.
anyone else had this problem and know a remedy for it ?? or do i just look up wayyyy too much porn ??
