In the process of buying a 4K monitor (42 inch Wasabi Mango - UHD420). It does 4K at 60 Hz on DP and HDMI 2.0. It has a Freesync window of 42-60 Hz.
The rig is intended for productivity and some gaming (a few hours a week - mainly FPS). I'm ok with 50-60 FPS if that is the tradeoff.
I've always been an Nvidia guy, never running SLI - but going for the top card. It appears that you need either CF or SLI to get games running in the 45-60 Hz window.
Question, from a non-AMD noob - is the Freesync worth the extra?
Should I opt for two Fury X and go into the dark? I understand you can't tweak the Fury X too much and there have been reports on pump noise.
Or should i go for the trusty Nvidia 980 Ti in SLI?
thanks!
thanks!
