- Aug 14, 2014
Hi, im not new to the overclocking scene, but im not a pro either, so would like a few tips if possible
i have been tinkering with my FX-4300 to see how far it will go with my current setup (specs below), because im not planning on upgrading until the new AMD gen pops up or until i burn this one
i would like to know what is the diference between OC by multiplier or FSB besides the basics and if there is any chart or common knowledge of which one is better or gives better values ? So far ive been able to push this baby far more with multiplier then FSB (4.8ghz vs 4.4ghz respectively) but obviously each has its benefits ? Pls bare in mind that GPU and MB aside this is a poor man's PC
Screenshots added and have been taken after Prime95 overnight, 0 errors
QuadCore AMD FX-4300, 4800 MHz (24 x 200) CPU 1.35v - CPU/NB 1.2v
Cooler Master Hyper 212 EVO - 1x120mm stock
Asus Crosshair V Formula
MSI GeForce GTX 660ti - N660Ti PE 2GD5/OC
8gb Corsair Vengeance LP CML8GX3M2A1600C9 - 9-9-9-24 1600mhz
64gb M4-CT064 M4SSD2 - System
500gb WDC WD50 00AAKX-08U6AA0 - Games
1tb WDC WD10 EARS-22Y5B1 - Backups
Corsair Enthusiast Series™ TX750 — 80 PLUS® Certified Power Supply
Zalman Z9 U3 - 3x Evo Labs 140mm 1000rpm (front, top) - 2x Evo Labs 120mm 2300rpm (back, bottom (PSU was taking too much space for a 140mm fan))
Acer H223HQ 21.5" Wide LCD Monitor
Windows 7 Professional 64bit
