Really pleasantly surprised by this CPU. Setup in a Thor 2 case with a CM Hyper 212+ on a GA-990FXA-U3 R5 board. Disabled APM, CnQ, etc. Enabled HPC and set LLC to medium and set Vcore from a base of 1.320v to 1.375v. I have an aftermarket fan on the CM 212+ and have it pointing toward the TOP of my case where a 230mm exhaust fan sits. The case has 120mm front intake and rear exhaust fans as well as 230mm side intake and top exhaust fans. Its pretty quiet as well. I'm running a single R7 370 GPU.
(HWMonitor and Core Temp report identical temps on my system)
OCCT misreports the base frequency of the FX 6300 as 3.8ghz instead of 3.5ghz
LLC on Medium kept Vcore at 100% load betweeen 1.356v and 1.38v
