FX-6300 OC
BMC
Hi guys, new to oc stuff so sorry if I'm asking garbage questions.
The setup is ASUS M5A78L/usb3, AMD FX-6300.
Do you think the board can handle overclocking? I've tried slightly increased multipliers and it seems that the multiplier jumps down when torture testing. Also cool'n'quiet and turbo core are turned off.
Is the multiplier jumping because my board can't handle the oc, or something?
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Yeah... junk board for overclocking. It's 4 phase power and no heatsinks on them. You need to add heatsinks and/or spot cool the VRMs for best rsults.
B
BMC
Would lowering voltage while increasing the multiplier yield any positive results, or would the VRMs still heat the same?
EarthDog
Buckeyes!
doesn't work that way.. in order to overclock, you add voltage. So as scotty said, you will run I to instability earlier. Junk board for overclocking man.. sorry.
B
BMC
Understood. Thanks for the answers both of you guys.
