Shazzrilla
- Oct 29, 2016
Hey guys, short version. I used to be into overclocking some years ago, and I've recently gotten the itch again. Primarily because I am waiting to see how the new Zen CPU's look, before I upgraded.
I have the following:
FX-8320 @ 4.65Ghz (I want more, hence the thread) (Currently: CPU(1.525v - 1.52-1.54v), CPUNB(1.3v), CPUPLL(2.67v) - I bought this I believe before the 8370 was binned.
2x16Gb Corsair DDR2400 C11(Yes, this sytem is running at 300 bus, 2400 HT, 2400 DDR, 2400 NB) - Stock 1.65v
Gigabyte 970A-UD3P - v1.0(This may be what is stopping me, forcing me to hit such high voltage?) -- Additional fan mounted to cool the VRM.
Corsair H100i v2, in a case designed specifically for airflow(there is nothing blocking two intake AF120's)
Corsair CX750M Power supply (Additional power draw is 2 SSD's, and one storage drive so Minimal.)
eVGA GTX 1070 SC(got one, bit that bullet. Plan to get a second one after next years CPU upgrade. Yes it's also overclocked. GPU(Boosts to 2100) RAM(8666))
The above is stable in both Prime blend, and Prime small FFT for 24hours.
Temps:
TMP1-MB: ~30c
TMP2-CPUNB: ~50c
TMP3-CPUSocket?: ~55c
Core Temp: ~55c
Additionally GPU never exceeds 59c
Now the questions. Am I reading these temperatures correctly? I am aware the VRM temperature does not report on this board.
How much voltage do you feel is safe? I see 1.55v all over the place, and some people who swear be 1.6v... and even some who say go for it up to where temps start to cause problems.
I am willing to take the risk with my hardware, as an upgrade is due anyway... and if it all dies... well I guess I will get a i7-6700k instead of waiting on Zen.
Goal here: 4.8Ghz ... or 4.95. I also understand my chip just may never do it. It may however at some crazy voltage.
Thank you!
Temps:
TMP1-MB: ~30c
TMP2-CPUNB: ~50c
Core Temp: ~55c
Thank you!
