FX-9590 @5GHz + EK Predator 360 stable
AMDFTW
Anyone with the EK Predator 360? I would like you to chime in on whether the Predator 360 able to handle the FX-9590 @ 5GHz and keep it stable or would you need a 480mm radiator?
Johan45
AFIK the predator isn't compatible with the CHVz
AMDFTW
AMDFTW
You should just need to buy another bracket.
Yup what he said. They offer it now (if they didn't in the past). Also, I'm thinking of getting the CFZ mobo waterblock and hook those up to a separate predator. So CPU/Mosfet/VRM should be cool enough to get 5GHz stable.
