So, is everything working properly, SATA, USB, Audio, etc? You haven't mentioned anything not functioning, just that the drivers are older.
If I had an issue @ startup like that I would be tempted to add a tick or two of voltage to the cpu and see if it cleared up. But you are pushing max temps for your chip already so I might consider dropping a couple hundred mhz instead. There are other things that might help - like adding a tick to the NB - but all options will likely add heat, and you are at your limit as I already said.
Adding a tick or two to various voltages is not guaranteed to add more heat though. It is just the nature of the beast that your chip might run @ 60C for the next 2/3 voltage increments - in my experience anyway. But the next increase could send you clear up to 65C. The only way to find out is to test I guess
Maybe increase the Vcore and reduce LLC by a notch each...
Any hope for Win8/8.1 drivers to work? If they exist?
Make sure the keyboard and mouse are connected to USB 2.0 ports. The USB 3.0 ports from that generation generally require drivers to initialize them.
The time issue is a bit more confusing. The only thing I've seen similar to that was caused from a virus/malware. I was unable to change the date or if I did it would change back. Be sure to run a respectable anti-virus/anti-malware just to be sure.
Turn off fast boot.
Lemme know if that cures your boot problem.
-snip-
I don't seem to have an LLC option, the Bios (Not UEFI) is pretty ordinary, I think I'm lucky to have any overclocking options at all. I will see about some more Vcore and see what happens.
What you need is a better cooler. The Wraith is OK but still not on par with a $30 Hyper 212
From a performance and vv. overclocking success, have you tried
out a RAM config of 2x2GB vs. 1x4GB?
You current RAM config seem be a bit challenging for maxing memory bandwidth by OC, IMO.
