FX6300 temp monitor
Chuy
Las Vegas
What do you guys recommend for monitoring temp? I downloaded cpuid hwmonitor and noticed the packet temp isn't available on the free version.
C
Chuy
Las Vegas
When to my profile, about me, then your system. It actually shows what I typed under your system just not when I post. I am doing this throu my phone if that makes any difference.
Johan45
You have to add it to your signature to have it show under your posts.
ATMINSIDE
Go in the top right to Settings. From there, on the left side, click Edit Signature. This is on the desktop site.
If you're posting from your phone are you using the Overclockers app, the mobile site, or the desktop site?
C
Chuy
Las Vegas
Im using the desktop site on my phone. Mostly because I like the look of it better over the mobile site.
ATMINSIDE
The signature, once you configure it like I just detailed, will show up then.
