- Feb 25, 2017
Hi guys
First of all my pc spec: Asus asus m5a97 r2.0, fx8300, Sapphire r9 280 trixx, hyper fury x 8gb 1600mhz single channel.
So i overclocked the fx8300 @4.2ghz and the cpu vcore is set @1.325v everyting else is auto.. I disabled turbo mode and the power saving options expect HPC is enabled. So i run occt test 1h and it went without any error temps were 52c cpu and package was 38c (cpuid hwmonitor) aida64 stress test went flawless but i wanted to try prime95 and so it begins normal till 720k process it passes the 720k and the my pc freezes
only option is to reset it on the case button! Testing with prime95 temps get 60c cpu max and package 45c max... What can it be? Is the voltage to low? I hope you can help me
thanks
EDIT: Amd overdrive stability test completed without error for 1h
