FYI...A7V133 bios flash
Mr wizard
seattle
I just did a bios flash on my mb .I did it on my deasktop asus update.When it said Flash done sucsessfuly and to restart and press deleate to enter new settings.Shut down went good,but no restart.....nouthing..nada...start to sweat...calmed down and tryed to clear C-mos.It is in a hard place to get to,so I made a tool out of tin foil and a screwdriver.Once done it rebooted and ran rite into startup.With the new bios.Now I can use the xp cpus.The new bios is 1008 and will let your mb clock up to 15+and 266fsb.
Anyway just my 2cents
Yodums
Senior Member
Ottawa, Canada
Wow crazy story. I had bios flashing, probably won't again unless there's a major reason. Bios flashing always gets me jumping, my heart is racing!
Oni
Oni-ni-Kanab;, Ninja Hippo eater Moderator
St. Catharines, Ontario Canada
I flashed mine to 1008 about 2 weeks ago. Went w/o a hitch, but it throttled back my ram from CL2 to CL3. Found out about a week later.
Oni
Under the 2nd tab, there should be a sub-menu for chip settings. go there, and there should be an option to either have SPD set your ram for you, or to do it manually. Do it manually, and change the values to 2
